fireball
I know people don't plan on having "accidents", but quite often practices change following an accident and in some cases legislation follows.
Whilst I welcome "advice" from investigation, if the advice leads to compulsory changes in practice or legislation then it may have a significant adverse affect on the rest of us.
Assume for example - that it becomes compulsory to stay in port if there is a F10 in the forecast - not unreasonable you may think - but that could be seen as rather restrictive if you have a sheltered local delivery to do and a window opens up.
Perhaps all commercial skippers may be required to submit their passage plans to the principle of the school - actually, that's not such a bad idea and perhaps it's already a requirement - but if required not to deviate from the plan (except in an emergency) then it may prevent a skipper from taking advantage of some unforeseen situation (eg light wind day - plan is to do a bit of anchoring practice - unexpected breeze kicks in which would give good opportunity to sail a different passage - but not "authorised" by the principle).
The RYA may feel it has to "crack down" on the way schools are accredited or even how certificates are issued & examinations take place - changes usually result in additional expense and/or paperwork for the school - using up valuable resource that could be put to "better" use.
As far as I can see Laws and Rules generally set out what are often common sense decisions - but you can never legislate against stupidity and in trying to do so it often unfairly restricts those of us with a degree of common sense!
