Stemar
I have a Navico WP500 wheel pilot and an Android tablet running Navionics. Is there a way to get them to talk to each other, so the Pilot follows a route?
No, Navionics doesn't output the required data.I have a Navico WP500 wheel pilot and an Android tablet running Navionics. Is there a way to get them to talk to each other, so the Pilot follows a route?
My B&G Zeus S has a setting where you can "pre-approve" turns up to x degrees under autopilot. Since it's a sailing yacht, I set that very low to avoid possible autopilot induced gybesThe AP's I'm aware of all require you to approve every change at waypoints.
Hence it is a helping hand but not much more.
I tried using my raymarine autohelm linked to the plotter to follow a track to a waypoint. Found it a waste of time at my speed of under 5 knots as the autohelm was working hard to follow the track due to tides and wind pushing the boat either way. Much more relaxing to set a compass course and occasionally tweak, especially to avoid pot markers !Thanks everyone. I rather thought that might be the case.
The idea was pure laziness on my part. In varying currents, just setting a course doesn't necessarily take me where I want to go, so I wondered if it could be made self-correcting
I agree.Is it really too much trouble to manually alter course in the vicinity of each waypoint?
I have never understood why I would want full A/P integration. We have it switched off. And this on a boat sailed over 95% of the time on A/P (well over 1000 nm coastal trips this year alone).
I like waypoints set a safe distance from rocky corners and (where these rare beasts exist) navigation buoys. Then depending on weather and other boats might turn sooner if weather and traffic permits. Flick off A/P, smoothly steer round, flick A/P back on, less than 5 seconds per waypoint on a voyage. Is that too involving?
So what happens if the “pre-approved” turn happens with other boats close by? Or pot buoys?My B&G Zeus S has a setting where you can "pre-approve" turns up to x degrees under autopilot. Since it's a sailing yacht, I set that very low to avoid possible autopilot induced gybes
