[32511]
Just appeared here: motor vessel with single white light on the foremast, and on the stern mast, from the top, white, red, white, red.
Any ideas?
Any ideas?
Red - white - red is restricted in ability to manoeuvre.
The other two whites could be normal masthead lights if under way, or anchor lights if stopped. You'd tell the difference by their relative height (which you don't mention) and the presence or absence of sidelights.
The way I remember this is based on the day shape for RAM - a diamond between two balls. Well, if you had a spiky diamond between your balls, you too would be restricted in your ability to manoeuvre. At night, the sore balls are red, and the diamond is shiny white.
Would you display restricted at the same time as anchored though?
Red - White - Red. Red When Restricted
like red over red over red. Rudder rubbing rocks - constrained by draught.
It's in the rules...
The term “vessel restricted in her ability to manoeuvre” means a vessel which from the nature of her work is restricted in her ability to manoeuvre as required by these Rules and is therefore unable to keep out of the way of another vessel
No use an anchor light the restricted lights are for when under way.
•(iv) when at anchor, in addition to the lights or shapes prescribed in subparagraphs(i) and (ii), the light, lights, or shape prescribed in Rule 30.
Off the top of my head I can think of two types of RAM vessel that might also be at anchor - diving support boats; and dredgers.
(d) A vessel engaged in dredging or underwater operations, when restricted in her ability to
manoeuvre, shall exhibit the lights and shapes prescribed in sub-paragraphs (b) (i), (ii) and (iii) of
this Rule and shall in addition, when an obstruction exists, exhibit:
(i) two all-round red lights or two balls in a vertical line to indicate the side on which the
obstruction exists;
(ii) two all-round green lights or two diamonds in a vertical line to indicate the side on which
another vessel may pass;
(iii) when at anchor, the lights or shapes prescribed in this paragraph instead of the lights or
Where I struggle is in thinking of the circumstances in which it is important to know that a vessel at anchor is restricted in its ability to maneouvre, but is not engaged in underwater activities - i.e. where it exhibits the lights required by 27b, but not the additional ones at 27d.
I think you've misread paragraph d. [snip]
No, no. Far from it. Note my words "the additional ones" in the final sentence.
One of us is confused - you wrote
I took this to mean that you believe the 27d lights indicate underwater activities - a boat with 27d lights is doing things underwater, and a boat with only 27b lights is not doing things underwater. Have I understood you correctly?
Pretty much, but just to clarify......
Putting aside mine clearance, all RAM boats (should) display 27b lights. A boat that is RAM and engaged in dredging or underwater activities also displays* (i.e. in addition to 27b) the 27d lights when there is an obstruction - with the 27d lights telling you which side to pass and which to avoid.
