chriscallender
I recently (June) purchased a Seal 28, and I'm delighted with my choice, having recently completed a channel crossing and having had a lot of fun over the summer.
However, there is one problem that I wondered if anyone has come across before? I posted this on the Seal Association web side but so far I have not had any replies there, so I'm also posting here to a wider audience for ideas.
When the lifting keel is in the down position and the boat rolls, a banging noise comes from the keel. In the sheltered waters of the Solent, this was not too noticeable, although I had heard happening it and I was intending to look into the problem over the winter. However, when crossing the channel with a relatively big following swell (1-2 metres?), the banging coming from the keel was very loud (both annoying and it sounded like it would be doing some damage to something). I had to lift the keel considerably (approx half way up) to stop the noise. Fortunately I was on a broad reach crossing the channel in both directions so I was able to do this.
I believe that the keel is moving laterally and in fact I once took the cover off and had a look into the keel box whilst underway. Its possible to see the keel moving by about 1mm from side to side which causes the banging.
In case it is relevant to the problem, the previous owner replaced the keel lifting wires last winter and I was wondering if these are not quite the correct length, so that the keel is not going down quite as far as it should and is "swinging" from side to side on the wires. Does anyone know if there is some kind of platform that top of the seal 28 lifting keel is meant to sit on when it is lowered all the way down?
Anyway, if anyone has any ideas then I'd be glad to hear about them. The boat will be lifted out on 28 October and I'm very keen to get this problem properly fixed for next season - if there is anyting that I need to try before the boat comes out to confirm the cause of the problem then I need to do it fairly soon.
Thanks for any help
Chris
Thanks for any help
Chris
