Nina Lucia
Lift, scrub and relaunch straight away in Solent, good value any where in Solent?
The Boat Lift, Haslar. Fast turnaround (one hour), good service. Not sure about good value - is anywhere good value in The Solent????Lift, scrub and relaunch straight away in Solent, good value any where in Solent?
I put this list together a year or so backAs an alternative, there's the scrubbing grid at Hardway. A tenner for the grid, another for the pressure washer, plus a token or two and you're done for change from £30. Two downsides, it's DIY and you're stuck for a full tide.
As far as I recall, Haslar could only do fin keel, so we went to Cowes sealift.The Boat Lift, Haslar. Fast turnaround (one hour), good service. Not sure about good value - is anywhere good value in The Solent????
Great recommendation.Cowes/Kingston Marine would be my recommendation:
Welcome to Cowes Harbour Commission
As ever, if it's only a mid-season scrub be sure to ask whomever is doing the spraying to use the correct nozzle and pressure setting as too hard it will simply blast off all the a/f ?
If it helps, Sealift at Haslar charged me £201 in October last year for a 10 metre yacht. Is that good or bad value?
Not sure that's the case; I've seen lots of bilge keels and mobos using the service. Just need to call them for a priceAs far as I recall, Haslar could only do fin keel, so we went to Cowes sealift.
You’ve been given lots of suggestions above. What update are you looking for?any updates on this as I need a lift and scrub in the next week or so
