Inselaffe
So, I have ordered a battery drill to wind up & down the keel on my ETAP 22. I think I need about 35Nm to be safe, and found that the combination hammer/drills are the cheapest option for the most Nm.
It takes 320ish turns top to bottom & there is no indication of how far up it is, I just count the turns I make by hand at the moment.
So, my plan was to attach the magnetic bit that goes on the spoke of a bike speedometer to the 'bit' that I have made that fits in the socket where the winch-handle type thing used to be inserted, and then put the sensor of the bike speedometer on the drill body. Then I can input the (fictional) radius of the magnetic bit to give me a circumference of, say 1m, and then I can estimate the number of turns from the trip distance.
But I'd have to remember to reset each time I changed directions as it cant see which direction I am going in.
Well, finally, to my question...
Anyone know of anything that could count in both directions (eg a mechanical counter, like the old style bike ones I remember)? Then I would always know where it was without resetting, which I know I would forget sometimes.
Maybe I could attach something like that to the boat rather than to the drill?
Any other ideas?
Sounds like a lot of fuss over nothing, but when I am on my own and running aground somewhere in a small creek, then a quick wind up with knowing where the keel is would help greatly
The set-up is as below, but with two crown wheels at the top to turn the rotation 90 degrees so the handle fits in a socket at the side of the tabernacle
http://i90.photobucket.com/albums/k259/leighspiccies/ETAP22_KEELSmall.jpg
Any other ideas?
