Jayayecee
New Member
When doing winter check on life jackets I was always careful to blow them up with a pump to avoid introducing moisture. I have lately been told this is not necessary. What is good practice folks
How do you deal with the valve when deflating with a pump? I inflate with a pump but deflate manually, sucking out the last of the air by mouth using my tongue to depress the valve.An inflate/deflate pump to pump air in and suck it out again and make sure the bladders pack flat. Jackets have had this routine for 9 seasons with no problems.
You shouldn't need to remove every last bit of air in order to pack the lifejacket successfully. And you should be careful using a pump to deflate due to the possibility of oral tube valve damage.How do you deal with the valve when deflating with a pump? I inflate with a pump but deflate manually, sucking out the last of the air by mouth using my tongue to depress the valve.
