LIDL weather station
roger
Overwinter in Sweden, sail in Northern Baltic, liv
I've just bought a "Digital Weather Station" from LIDL. There may still be some in other LIDLs
It's quite large at 14 ins. high by 5 1/2 wide and will hang from a screw.
Measurements
Temperature inside and outside
Barometric pressure (accuracy not stated)
Time by radio controlled clock with alarms
humidity
Weather prediction (little pictures) and trend record
cost about 15 pounds.
It is reasonably attractive with central stainless steel vertical panel and black outside panels.
The remote thermometer has an internal thermometer and has to be protected from water which is a disadvantage. Otherwise it seems to work.
I hope it works better than the one I bought from Lidl last year. I found it very erratic and obviously mis-reading the temperature. Wherever you place the outside sensor it appears to give very high or low readings. The sensor holding bracket is very fragile and the slightest touch would send the sensor flying, with subsequent loss of batteries from the case. Would not recommend it. Good luck with yours.
