Lidl Fishing Gear?
rob2
23 Aug 2005
Hampshire UK
So long as you don't catch anything too big, they should suffice, but you're right that a boat rod is better at only around 1m long and most are rated to 50lbs or more. It isn't uncommon even in the Solent to be fishing for smaller species and accidentally hook a smoothound - a small shark. Landing gear such as a gaff is required if the rod can't bear the weight - and the shark family make good eating, just try rock salmon from the chippy! Even a half decent sized cod would be quite a handful on an overlong and bandy rod...
Rob.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I have to say that 'pilk' was a new word for me (it's new to this spell check too). Googling it was not helped by the search engine's insistence that I was looking for a pink fishing rod. Even when I found a site that was about pilk rods it still could not tell me what they are.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
A quick google seems to indicate that a Pilk is a Pirk by another name. A pirk is a dummy fish with a hook on the end. Apparently another name for a pilk rod is a jigging rod. Funny people these fishermen.
Highndry
7 Apr 2011
Nr Uppingham, Rutland
Steer clear, I know fishing tackle and this stuff isn't in the same league as their DIY products. If you really want a rod for boat fishing, look for the best price you can get on a travel boat rod and the shorter the better. A stand up rod (so called because they're designed for playing fish standing up rather than sitting in a big game type chair) is best but difficult to find in a travel rod. The only range I know of is Shimano's XTC range. When assembled they're short enough to be used under back stays.
rbmatthews
15 Nov 2010
North-east Scotland
rubytuesday39.wordpress.com
Pilk seems to refer either to a carbon fibre rod (http://answers.yahoo.com/question/index?qid=20080330090305AAIgmIL) or is Norwegian for pirk (http://no.wikipedia.org/wiki/Pilk). Given that the Lidl ad refers to the rod rather than hook, it seems as though it might be the first of these.
Whatever, we always carry two 2-piece boat rods similar to the Lidl Pilk rod - cheapest of the Shakespeare range with multipliers - we've caught loads of cod and mackerel with them, and they are still going strong after 7 years.
Rob.
Highndry
7 Apr 2011
On second thoughts, if you want cheap and cheerful (and Lidl's3 year warranty) the Pilk set is the one to go for. For jigging jigs, feathers or pirks up and down from the stern it will certainly do the job. However, it is a £19.99 outfit, it's not a heavily discounted £50 outfit.
My comparison with their DIY products is based on the fact that you'd struggle to get anywhere near the quality of their £49 crosscut saw for double that in a DIY store, you can pick up rod and reel combos like this for around £25 quite easily.
In my opinion, the best length for a boat rod to be used on a sailing boat surrounded by rigging is six feet or preferably less. The reason I like the Shimano XTC range is that they're easily transportable when I travel abroad to charter.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
if you want cheap and cheerful (and Lidl's3 year warranty) the Pilk set is the one to go for...
you can pick up rod and reel combos like this for around £25 quite easily...
Cheap is important, as I will rarely use it. I wondered about throwing away the thin section, essentially then a reel on a 1m stick.
Where else should I look then?
Highndry
7 Apr 2011
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
Look in second hand shops, auction houses & local internet sales sites (ie on Face book etc) you may pick up a reasonable used one cheap. I was given a decent but old boat rod set up by a neighbour of my dad's who remembered me as a kid. The kit is probably from the 60's but still works fine when it gets pulled out of the aft cabin twice a year.
I also have a couple of cheap telescopic rods for spinners that I got from toy shops that keep the grandkids quiet for a while, but of course they never catch anything!
rbmatthews
15 Nov 2010
North-east Scotland
Why chuck away the thin section? If storage is an issue, it folds up to about 1m anyway. It would be difficult to get anything new much cheaper than £20 with a 3-year warranty to boot. I'd go for it - a few good mackerel and it will pay for itself in no time even if it lasts only three years!
R.
srp
10 May 2006
Barnard Castle, Durham
Never used a rod for mackerel - some 1mm or 1.5mm line wound round a bit of plywood, a weighted paravane, 5 feathers and a spinner on the end is all you need. Occasionally catch bass and pollack on this rig, but generally it's very selective so nearly all mackerel, with the odd garfish in very hot weather.
Always use a rod when spinning for bass though, with an unweighted rubber sand eel - in the old days we called them Mevagissy eels.
Highndry
7 Apr 2011
Mackerel on a light rod are fantastic fun. Multiple mackerel on feathers on a heavier rod (like this one) are also great fun. However, the boat rod on offer here is a pilk (pirk) rod which is designed to lower things down (feathers attached to a lead weight or heavy pirks) and simply work them up and down. Ideal for mackerel and pollack. As a boat rod it isn't designed for casting (tip isn't flexible enough) so the only way you're likely to catch bass is by fishing on the bottom with bait or towing a lure (such as a rubber eel) behind the boat.
The advice about second hand shops is good but you really need to know what you're looking at. There's an awful lot of over priced (through ignorance rather than greed) **** in most of the second hand shops I've seen fishing kit in.
