andyball
A friend has a leyland 401 engine in his boat : the starter motor looks like an inertia type (no piggyback solenoid), yet has a small terminal that is connected to a largish relay(doesn't look big enough to carry the main starter current).
Anyone know if that sounds right? is the small terminal connected to some built-in solenoid or relay ?
fwiw, nothing happens when 24V is applied to the small terminal (draws current, but no movement/sound) .If 24V connected to the main (larger) terminal, motor spins away.
Thanks in advance.
Thanks in advance.
