D
Deleted member 36384
Hello,
I would like to change my old Morse control to a new Lewmar control as per the link.
Engine control with single lever LEWMAR
My query is about the throttle lever and if it can be mounted in any position. The throttle housing on my boat is a recessed arch. The cable operating mechanism is horizontal. The Lewmar cable operating mechanism is vertical, the majority of which would protrude into my cockpit locker and be at risk from moving objects.
I can mount the Lewmar throttle device so that the cable operating mechanism is horizontal, but I would then have to orientate the throttle lever by 90 degrees so that it can operate across the full range of movement, within the recessed arch.
Can the lever be mounted in any position on the splined shaft?
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
