Without triggering another endless anchor debacle, has anybody had first-hand experience of this anchor on the muddy East Coast? It's branded, its cheap, but is it better than an old style CQR?
Looking at the piccie ... there are 2 points that spring to mind .....
a) The stock and plough blade appear to be locked and not pivoting very well ... the plough partly relies on this pivotal movement to get it to set ... b) the metal used appears to be shiny .... not galvanized or forged.....
or is it that it's just new and has an invisible prop ? E-Bay ?
Thanks, seems that it is a not genuine and therefore the post has proved it's worth. Its just that I did not recognise the design and it seems many on forum didn't either.
No, I spent a bit of time looking around the interweb and couldn't find it. Lewmar don't seem to claim it and neither do Holdfast. It looks like a welded construction anchor, not normally recommended although I'm sure I don't know why, as most technical engineering equipment is. I suppose it gives lots of opportunity for the backyard brigade to include slag, porosity, poor adhesion, etc in its manufacture. I wouldn't like to trust it.
That looks pretty much the same as the anchor that was (presumably) standard kit on my 1990's Moody which is marked 'hi-blade'.
Sets without any problem in mud. No experience of it otherwise
or at least recently that such designs as CQR ran out of copyright exclusivity etc. ....
Surely there have been many copies that alter the design enough to get by ... this may be one that has stayed in pristine condition through no use ?
The genuine CQR USED to have a lifetime g'tee .... but that was removed years ago ... and claims of its strength durability cont. but without the fallback. It is accepted that copies have failed on shank pins, shafts, shackle eyes etc. - along with having excessive loose pins / pivot points....... the list goes on.
But at end of day most have worked ... for years or whatever ... yes buy genuine if you need peace of mind ... for me - most achorages I used were drying anyway - so I knew what I was anchoring in ... copy or not really made no difference.
