Lewmar 34 ST - help
Anchorite
22 Oct 2002
FRANCE nr. Lyons
The 34 ST was discontinued about 20 years ago and (good old) Cruisermart
sold me one during the eos sale. Its moment of glory has now arrived but I
can't disassemble it for installation. The stripper arm has no visible screw,
circlip or other thingy to enable lift-off. I've tried gentle persuasion to no avail
so (before the sledge) can anyone help? Lewmar's site couldn't.
snowleopard
Oxford
i don't know the st34 but have stripped various lewmar winches. these are a few of the possible first steps:
on my st40 there is a conical chrome ring around the handle socket with two triangular indents. in the absence of a special tool you can use two big flat-blade screwdrivers crossed over and fitted into the indents. it unscrews anticlockwise.
failing that i would look for a large slotted screw at the bottom of the handle socket (no, that's too obvious)
some lewmar single speeds had an odd circlip around the edge of the socket, it was a keyring-style circlip easily removed by levering under the end with a small screwdriver.
when you lift off the stripper there are a couple of keys with teeth that engage the stripper. these are a loose fit into the central spindle and fall out once the stripper is removed!
tome
28 Mar 2002
kprick
www.google.co.uk
This sound like the modern 'Wavespring' version of the 34ST. The older Wavegrips had a a cap with 4 screws on top.
If it is, there should be 2 indents in the cap. You can gently drift these to unscrew the cap (anti-clockwise). After it moves, you should be able to unscrew by hand.
You can download a good guide to servicing these winches from
<A target="_blank" HREF=http://www.lewmar.com/support/index.asp>http://www.lewmar.com/support/index.asp</A>
Anchorite
22 Oct 2002
FRANCE nr. Lyons
Re: Lewmar 34 ST - problem solved.
Thanks to you both. There are no indents anywhere but by blocking it with a
winch handle and twisting (a rubber mallet was at the ready but not necessary)
anticlock as advised, the stripper unscrewed easily.
