Lewmar 185 TT Thruster. 3kW Thruster in trouble again!
Kinsale373
15 Jan 2017
Kinsale Irl
I see some discussions on these in the Past. My unit is only working in one direction. I think that its the Black Box this time as when I jumper the connections going into the Black Box I get thrust on one side but not the other.
Im thinking of just using a toggle switch at the helm to switch 12 V directly to the Albright , reversing relay contacts. (Get rid f the Lewmar ontroller and Black Box) When i look at the Spec Sheet for the relay it seems to indicate that the the Coil Spec is 10 to 15 Watts for Continuously Rated types and 40 to 50 Watts for Highly Intermittent rated types. In other words I could be drawing up to 4.2 A to drive the coil ( worst case) I'd need a switch rated for that.
Does what I'm proposing make sense? Has anyone made a similar modification?
Kinsale 373
I just set up an old Albright Contactor that I had in the workshop. The Coil draws 1.6 A at 12V to energise it , so if I can get switches rated for say 5 Amp , I that think I should be able to drive the contactor directly and take the balck box out of the system. Am I missing something? I see some previous posts where guys were talking about relays? Anyone any experience or ideas?
Rgds, Ted
