contessaman
Just took delivery of an ebay 60 watt flexible solar panel. £220 delivered.
construction appears reasonable for the money. aluminium sheet, coated in tedlar, cells laid on that then more tedlar. wiring looks a bit fragile will have to beef it up.
tests so far on a bright winters day with a watery sun low on the horizon:
midday angled panel towards sun: 20.1 volts, 2.1A
laid flat: 19.9 Volts, 0.8A
first light in the morning, sun below horizon
19 volts, 0.25 A
dark overcast day 18.5 Volts, 0.2 A angle makes little difference.
Its quite sensitive to shadow -even covering a small area of the panel causes a substantial loss in current so I will need to park the boom over to one side (going to mount it on top of deck saloon).
I suppose the quoted power is in the middle of a nevada salt lake at midday so the figres arent too bad.
Hopefully these figures are of use to potential purchasers, be interested to hear how your more expensive panels perform.
19 volts, 0.25 A
