Leg Alignment
skinnylegs
28 Jun 2004
Hi all
Am new to the forum and would like some feedback on leg alignment. Mercruiser Bravo II's
When viewing the legs from the stern of the boat the legs are not aligned with each other. Is this normal or should they be perfectly aligned with each other.
With both engines in ahead and steering straight the boat tends to veer to one side.
Thanks in advance for your replies.
Wayne
SteveJ
30 Nov 2002
Nanny Cay Marina Tortola
do you have handed props on the legs? the stern drives should toe in a little the boat builder should be able to tell you what they set them at or your local mercruser dealer.
PhilF
18 Jun 2001
In a state
When the steering is centred, are the legs centred.
There is a rod across the back of the transom that can be adjusted to centre the legs to the steering, been there had the problem.
PhilF
KevB
4 Jul 2001
Kent/Chichester
It could be your wheel is not straight and in fact the steering is straight when both legs are 88.5 degrees to the transom, or 91.5 depending on what side your measuring?
Col
14 Oct 2001
Berks
Sounds about right. They shouldn't be parallel.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
