Leech line and in-mast furling
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I have 49 footer with in-mast furling. I am now approaching the end on my first year of boat ownership and am just beginning to rise up the learning curve
The main sail has a leech line. I have been told by someone that I should sail with the line tight, but loosen it to furl the main away. Is this right? How practical is it to loosen the line while at sea prior to furling?
Boyd
Yes it would be better for the sail if you ease the leech line, this should present no majour problem when at sea.
Having unfurled the sail you want to pull the line just tight enough to stop the leach flapping
How does he do that?
(either of "that")
There you are, head to wind with the leach line jammer a couple of feet (at least) over your head, (unless you're sailing a midget yacht) slatting from side to side, trying to get a hold of it before your mainsail wrecks itself.
OR
"Having unfurled the sail..." with the boom having taken the leach (and the jammer) now supposedly to a sailing angle so as to be able to experience the "flapping" you describe - obviously not possible whilst head to wind - how do you reach the jammer (OK I can't remember the posh term for it - no sailing club of merit ever let me join!) unless you have the arms of a gorilla?
It is a useful bit of kit but not really user-friendly.
Steve Cronin
Re: How does he do that?
Even cleverer sailmakers run it over the head of the sail and down the luff so that adjusting the outhall doesn't change the leach line tension.
Well exactly.
Don't ever remember seeing a leach line on a roller furler the few times I've sailed one.
