AnneW
Having seen a reference to the use of LED lights as an alternative to normal bulbs (use much less power and last longer) I tracked some down in England but they were £44 each!
So I found some 12 cluster LED bulbs on the internet for $6.99 each that had the same bayonet (15b) fitting and said they were suitable for 12v. I ordered them on and they were duly delivered. I put them in and they didn't work. So I contacted the manufacturer who pointed out that I needed the correct polarity in my light fitting. Apparently positive at the tips and negative for the casing. So I took the light fitting to pieces to see if it was possible to change the polarity and then chickened out as I don't know anything about 12v systems other than there is polarity on the whole system. Is it possible to change the polarity on my light fittings or should I just give up and chuck the bulbs I've got away?
