AnneW
As some of you may recall I bought some LED light bulbs from the States and was having difficulty getting them to function. I did eventually manage to sort out the polarity. The long and the short of it being that although they were dual socket bayonet fittings they wouldn't function in a normal dual socket so I had to purchase some new light fittings which have negative polarity attached to the casing. Anyway several of you asked me to feed back on the volume of light given by a 12 cluster LED light as opposed to a normal 5 or 10w bulb. They do not give off anywhere near as much light (about a third) and the light is a lot more concentrated, giving a pool rather than diffused light. (That is partly because the only fitting I could get with the right wiring was a spotlight). That being said, they only use about a 10th of the electricity so you could install more. I am going to put a couple of double lights in the front and rear cabins instead of the current lights (particularly as these are the ones the kids forget to switch off) and maybe one in the main cabin for making a cup of tea when everyone else is asleep. But for main cabin lighting there is still a little way to go yet. I'm glad I didn't pay the £44.00 for one that they were advertised at in an English chandlery recently.
