Jonny_H
Just thought I would let you know of a successful plan we hatched whilst away this summer. We bought some of the battery powered LED lights ( Osram LED Dot-It ) - they take 3 AAA batteries which last for around a thousand hours and are self adhesive so can be stuck anywhere.
We also bought some cheap red nail varnish and put 3 coats on the lenses - then stuck them next to our existing cabins lights above the chart table and galley - they are seemed to work very well for use at night and don't draw any power from the main battery bank so will be a good backup in an emergency.
We also installed a couple without painting the lenses in areas where we short on lights (above the pilot berth for instance) and the light from these is quite blue so wouldn't recommend using them throughout the boat as main cabin lighting!
I forgot to take a picture but will do when next on the boat.
Just looking around for some LED bulbs to replace the other cabin blubs now (G4 fittings) and we should be much more battery friendly - anyone any good suggestions for sourcing (we need 6 to begin with)?
Jonny
Jonny
