capsco
Not had much luck with the search on here, so help please, where is the place to buy LED bulbs? in my case 24v.
You can do what I do and build your own from scratch, or replace the internals of an existing light with LED internals, you need to be able to do a little simple maths, be able to calculate resistor values, and the worlds your oyster as far as design and build go, Its much cheaper than buying new and if the lights not right you play with it until it is.
I blow my nose at your warm white, and all your silly candle coloured lights. Its mother was a hamster and its father smelt of elderberries!Warm white is the best IMO
I bought mine from Freedom boats in Macclesfield. They are narrow boat chandlers and as such prices were very reasonable compared to yacht chandlers
http://www.freedomboats.co.uk/
There is no such thing as a 12V or 24V LED, they are just normal LEDs with a resistor, or a voltage regulator.Seem like 12v only from here
What happened, it posted before I finished.
Above: this is where the LED lights are called 12/24 volt rated or suitable for both voltages or multi voltage.
Yes you can get 12 volt and 24 volt rated LED lights as many are either rated for a 12 volt input or a 24 volt input, particularly in the vehicle market as many are cheap and don't contain any form of voltage regulation, just a resistor to match the seriesed LED's to the maximum supply voltage which is usually 14.4 volts for a 12 volt LED bulb as this is the maximum voltage which can be delivered to the light if the alternator is working at maximum voltage; when the engine is switched off and the battery supplies around 12-4 volts having an unregulated voltage means the voltage drops at the battery and the light output at the light drops in relation to the voltage.
Which is the sole reason I regulate the voltage locally to the circuits, much the same happens when the alternator is charging as I have previously mentioned.
You don't need a constant current driver, its just another way of achieving the same result.
My dislike of replacement bulbs is that they suffer the same foibles as ordinary bulbs, they require a good contact in a holder and they can move in heavy swells which can disrupt that contact or corrode, hence making my own and wiring them in directly. My other preference is the directional light they offer, you can aim light where you want or need it, you don't have half the buld bouncing off reflectors and providing ueless light.
