aidancoughlan
The Strangford Narrows are at the entrance to Strangford Lough on the East coast of N.I. just to the west of the south end of the Isle of Man. Strangford Lough is a tidal inland lough about 15 miles long and all the tide flows in and out through the narrows between the towns of Portaferry and Strangford. Spring tides flow either way at 8-10 knots at the narrowest point. There are two interesting effects.
Firstly the narrows flow out to the south-southwest and the prevailing winds are straight up the Irish sea from the southwest. On a spring ebb in a (very common) strong southwesterly you get huge, very short seas at the "bar" - typically 10m apart and 6m+ high. A real problem in a rib! (or other planing boat). The tide in Strangford is also two hours behind the Irish sea, so you get the "falling off the end" effect to make things worse. The IOM guys are often faced with this when heading home (comments please).
Secondly the lough receives lots of river and rainwater into it, so the water is somewhat less saline than the sea outside. So on an ebb tide at the bar when the less salty water meets the more salty water, the outgoing flow goes "underneath" the standing water, taking with it loads of air in rougher weather, and forming a huge standing wave, like stepping off a 2-3m waterfall. I have gone out in a yacht at half tide and the boat sinks almost to the gunnels in the bubbly water as the density of the water/air mixture is much less than ordinary water. It is very frightening!
Sitting in Portaferry library, just found above on another thread (no direct responses).... leaving tommorow, predicted S F4, heading for Peel. any advice from anybody experienced in leaving strangford ?.... will a F4 southerly create a big standing wave or does it require stronger wind conditions to whip it up ? Boat is a 27ft Westerly. Thanks for any responses, will check back in a couple of hours!
