Puggy
Hi there,
I have a plunger type oil extraction pump bolted to the side of my Ford 2722 engine, and it is leaking oil around the plunger handle, either when operated or especially when the the engine is running, and it is making a mess of my engine bilge.
Can these pumps be rebuilt with a new seal? Or are they a standard item that you replace from ASAP or similar? My plan B is to remove it and cap off the pipe from the engine, as I use an oil vacuum pump down the dip stick to,change the oil.
Puggy
Puggy
