Dino
Hi, I’m currently away doing some extended cruising in Cornwall. On an earlier passage I noticed that I had a bad leak in a semicircular deck hatch. I removed the hatch and resealed it with butyl tape and Sikaflex 291i in all the screw holes. The hinge was very stiff and even good doses of WD40 wouldn’t free it. Once refitted I noticed that the riveted hinges are loose and the stiff hinge is preventing it from closing fully. I tried filling the gap with butyl tape but water was still getting in. A temporary fix has been a heavy plastic bag taped over the hatch.
I’m tempted to put a bead of Sikaflex around the seal and deal with it when I get home.
Will Sikaflex work on a rubber seal?
