Slipperman
Ever since I have had my boat I have noticed that a small amount of fresh water appears behind the engine and adjacent to my small calorifier. There are no obvious leaks from either pipe connections or the calorifier itself, but there is a small spring loaded relief valve which spurts out water if you touch it. The small amount of water has not worried me up till now, but recently I seem to get more to the extent that some water is finding its way into adjacent bilges from which it is difficult to extract except by removing floor boards, the engine box etc.
The small relief valve does not seem to have any adjustment on it, and I wonder what has caused it to leak more, if indeed this is the cause. I seem to get most water when the boat has been heeled over, and of course that is when it tends to find its way into inaccessible places too. Any ideas how I can reduce this leakage? I did wonder about leaving off the electric fresh water pump except when I need to use a tap (usually the switch is made as soon as I switch on the boat electrics, and then stays on throughout). Would this make any difference do you think?
