leaking windows ?
SAWDOC
24 Feb 2008
Ireland West Coast
I have a slight but annoying leak in my main cabin window, dribbling down from the corner. Is it on to simply prise out the seal and squirt a bead of a suitable sealant between window and seal? If so, what sealant would be most suitable?
It's hard to comment without knowing the details. I once cured a leaking window in an aluminium frame with Creeping Crack Cure. A couple of applications lasted for years.
If it just slight leak Captain Tolley's Creeping crack cure http://www.captaintolley.com/ will deal with it
Thanks JohnAlison and Vic
I am delighted with your suggestion as there is a bottle of the stuff left on board by the PO - thought it was for repair of minor gelcoat cracks - now I know better!
I found Capt. Tooley too runny. I now use Creepy Crackseal from Burgess Marine and have successfully cured leaky windows and hatches on my boat. Again a number of applications are needed. And wipe surplus crack seal off (that goes for both products) with a cloth.
