eddystone
At the end of last year, I had a drip out of the slot on my water pump, and subsequently had the shaft seals replaced; the guy showed me the shaft which seemed OK so left as is. Since re-launch it has a drip, not while it's running but after switching off. It's not from the slot and it's not from the gasket on the impeller housing; it looks like it's oozing from a crack in the top of the casing, at the front where the inlet and outlet pipes are attached. Is this plausible?
Had a reasonable quote for £200 only slightly over exchange price which is obviously not possible with a non-reusable casing.
