Skylark
The single lever mixer sink tap in the heads of my Beneteau is leaking. It seems to be from the hot water side in that if the lever is fully to the right, cold, there's no drip.
I've read that single lever mixer taps are likely to use ceramic discs to create the seal rather than rubber washers found in "normal" taps. I've also read that when leaking, a replacement cartridge is required. That's about the sum total of my knowledge so far......I haven't removed the lever mechanism yet. Here's a picture.
The tap is 18mm. I expect that I'll need a mortgage if I buy from the Beneteau network....has anyone any experience of this issue and found a way to repair it or found an alternative source for a replacement?
On the same tap, when venting the air after winter hard standing, one "surge" blew-out the aerator. I bought one that looked similar from ebay but it's very slightly different and there's no room for the o-ring seal so it weeps around the thread. Any ideas to source one of these......picture
Appreciate any help and advice.
