JollyRodgers
For those of you who remember my last thread about the sea toilet not working, I fixed that by replacing the water pump.
Now I have the exciting problem of the left seacock next to the toilet leaking ever so slightly. I believe that this is the 'waste out' seacock.
Not entirely sure where exactly the leak is originating from and I dont recall there being a puddle on the floor when I first get to the boat, which would indicate that the water is only coming out when I open the seacock to pump out the waste..
I tightened up the bolts at the base of the seacock (it was hard, they were very tight anyway) and that hasn't seemed to make a difference.
I am now wondering if the leak is starting from further up the seacock and trickling down into the base of the seacock, as it was damp up there too and surely if my seacock was closed and there is no leak and only leaking when it is opened (whilst it is being pumped). Just looking at this video now, perhaps I should tighten up the top bolts that come out underneath the lever, I didn't do those when I tried to stop the leak?
I serviced/greased up the seacocks as they were seized when the boat was out of the water last month. If the leak was at the bottom of the seacock, would I be okay to sparingly put a little bit of epoxy miliput down there?
If the boat was out of the water, I would just buy new seacocks and install them as they are in a naff condition anyway (not my fault).
Apologies for all the erms and ahh's. I had loads of distractions and my phone was going beserk whilst I was using it as a torch.
