steved
The rudder stock on my boat is leaking enough to set the bilge pump off every so often, it's Tides Marine setup with a lip seal as per photo's.
Once everything is removed from the stock it should be reasonably straight forward job to prise the old seal out, cut if off and insert the new seal.
Dare I change the seal whilst the boat is still in the water? Or do I go for a lift out / in (£500 ish) to replace a £30-40 seal?
What would you do?
What would you do?
