Jegs
Help,
I replaced a leaking prv with a new one & still have the same problem.
The pump is rated at 2.5 bar, the valve 3.0 & the accumulator [if relevant] max 8.5.
The top of the accumulator is above the main tank but below the top of the hot water tank: with the pump switched off I released the valve on top of the accum. with a small fountain being the result. I thought that these things had a membrane inside which would have prevent such a gush, am I wrong again?
Might a build up of calcium in the hot tank cause the problem?
Mystified & hopeful,
John G
John G
