Leaking Echo Sounder
MADFISH
11 Dec 2002
Solent, Marchwood (UK)
Can anyone offer advice re my echo sounder problem?
I have a Nasa echo sounder and the transducer sits in an oil filled tube. Problem is I clouted it while putting the inflatable away and now it leaks. It is hard to fix as the area is covered in oil. Can I fill the tube with epoxy and sit the transducer in that, thus bonding it in or will this not work?
Any suggestions would be welcome.
DanTribe
8 Jan 2002
Essex
It's probably easier to bond in a new tube than to try to repair a damaged one. Either buy a pukka kit from NASA or use a bit of 38mm plastic plumbing waste pipe.
Dan
MADFISH
11 Dec 2002
Sorry, I wasn't clear. The tube is fine. It is just coming away from the hull. This would sound like just a case of epoxying it back down but the area has become impregnated with oil over the years....I'm after an easier fix.
Spyro
18 Jan 2003
Clyde
I had a very similar problem I tried refixing it with epoxy but it still leaked I eventually repaired using ultra sound gel instead of oil the kind they rub on pregnant womens bellys I don't know if you will find any in the chandlers though, its thicker than oil so does not run out of the tube, it's still working fine after 6 months. I don't know of any other alternatives
omega2
17 Oct 2002
Essex Bradwell UK
put the transducer in a bag of water and try other areas on the bottom of the boat when you get a good return echo from a clean area refix the tube or epoxy the transducer itself to the hull.
<hr width=100% size=1>J HAMER
