Saddletramp
Thanks to advice from forumites I located the problem in my leaking bilge keels on my Mac 26. It was as suggested a puncture, about 1/2 " across on the corner of the base of the keels. Water was working up through the encapsulated ballast. I suspect it had been going on from a long time as there was evidence of filler inside. Epoxy putty ( 7 quid) did the trick for now.
The gel coat has worn off the base of the keels so it will have a wooden shoes fitted as advised. The surveyor had advised that I fill voids in the keel with foam to avoid frost damage. They would not have shown as being wet as the boat had been out of the water for 18 months prior to purchase.
Thanks to all concerned. Here's a pint
/forums/images/graemlins/smirk.gif
