Leak through windscreen seals
rafiki_
19 Jan 2009
Stratford on Avon
I have rain ingressing through the windscreen seals. Any cure for this short of changing the seal? This appears a major task as the alu frame is screwed in and screw heads are not accessible without a major dismantling job. Windscreen and frame are Trend Marine products.
I’ve just done my windows, with the same problem, in situ. I gouged out all, or all I could get, of the old sealer, cleaned with a scotchbrite, primed with Sika Activator then sealed with Sikaflex 255. It seems to have done the trick.
As above using a sealant designed for aluminium and glass, saves the priming stage. Did mine 12 years ago and still dry.
Sikaflex 255 is designed for aluminium and glass for use without a primer, but as the job is a pain in the @rse, I thought I'd make sure it would not need doing again in my lifetime!
