Leighb
I have just discovered that we have a leak through the deck, and am pretty sure that it is around the deck filler for the fuel tank.
It appears to be attached with 3 stainless self tapping screws, I can feel the sharp points on the underside. I was a bit surprised that they were not machine screws with nuts. Is this the normal practice, and would I be OK to just remove, clean up and rebed using the existing screws, or should I refit it with machine screws?
Also what would be the best bedding compound to use for this?
