lcd display depthsounder
Ardenfour
7 Feb 2004
Port Bannatyne
hi. does anyone have any knowledge about whether the contrast can be increased on my autohelm st50 sounder? I dont mean the user adjustable function, which adjusts as normal. However increasing the contrast to maximum simply increases the visibility of the unused segments, leaving the active ones still a grey rather than black. Extremely poor at any daytime viewing angle, and next to impossible to read at night with backlight on. Do these displays wear out? or do these symptoms suggest component failure internally?
thanks
Ships_Cat
7 Sep 2004
That certainly is not normal for the ST50's so you have a fault - as you are probably aware. I suspect that it will be the LCD display aged and it would have to be replaced to cure the problem (could be expensive, if the part is available).
As Bruce has said LCD's do not like long exposure to sunlight and in my view should be covered when not in use (even when passage making).
John
<hr width=100% size=1>I am the cat but I am only 6.
Ardenfour
7 Feb 2004
Port Bannatyne
thanks, I eventually suspected the voltage, but then tried the unit at home using a 12v adaptor and got the same results. Guess the units due for burial at sea...
dickh
8 Feb 2002
Suffolk
I also have ST50's and have noticed that they are sometimes difficult to read in strong sunlight and one in particular seems to have faded more than the others. Put it down to age & the technology of the time. They are always covered up when not in use.
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
