Rick_A
Hello guys,
Im searching for a cheek block that can take the strain of the genoa on my boat. And the strain of working while under load. We used to have (around 15years ago) the largest of the barton ones, size 4 i think, but it just twisted and was basically pulled apart by the strain in a couple of days.
The block will be placed behind the winch and bring the sheet back to the cockpit taking the rope. The port side sheet cuts into the teak when under strain so the new block is to divert the sheet.
The sheets are 14mm.
I have only looked at the online chandlers and there isnt much available from them other then the barton gear.
Im not sure of the weight that the genoa will put on the block but i could imagine in a good blow it will be well over a ton.
Any advice is apprecited. Moving the winches is not an option either.
