superheat6k
Occasionally I have trouble starting my engines due to voltage drops to the engine control supply whilst the starter is spinning, e.g. If the battery is slightly undercharged, or if as has more often been the case so called heavy duty battery switches are not up to the job (black body red key single pole type). If the control voltage drops below ~8 volts during the start the stop solenoid drops out, preventing the start required.
As an aside I have also noticed occasionally the engine will start and then cuts out as the alternator excites. If it does do this it then becomes a real pig to get to start again.
The problem hasn't been helped by a considerable volts drop across the battery single pole isolator switches (black body with red key type), so having changed these only recently I have now float tested the latest piece of junk in favour of a decent heavy duty switch.
The Corvette electrical distribution engineer was also less than clever with where he placed the 12 volt service distribution in a deep floor locker an extra 2m away from everything else electrical, so in a fit of pique yesterday I ripped the entire distribution panel apart and I'm now in the process of rerouting all the associated cables, heavy, medium and light, to a more suitable and indeed accessible position. The new switches Force 4 offered are rated for 1,250amps start current and are surface mounted so will be suitably mounted adjacent to the rest of the electrical distribution panels. The various distribution MCBs will be going inside the locker behind the helm where to my mind Corvette should have placed them in the first place.
So the cabin has a snakes' wedding in progress presently ! Fortunately I was calm enough to tag each wire as I disconnected it, and presently I only have two out of some 25 wires that I am not sure what they serve. Will soon have these chased out.
However, to better overcome this I want to draw the control power much closer to the battery rather than right at the starter connection, where the voltage drop at start up is at its most. plus I am going to fit cross over supply switches so the port engine control can draw its control supply from stbd battery or vice versa.
To do this I need some larger than standard spade terminals for my engine control power supplies. The standard large crimp spade terminal flag is 6.3mm wide. The ones supplying power onto my ignition switches (Cummins) are ~10 mm wide. I could cut the existing cable a few inches back and graft on the new supply cable but this seems messy for the want of the correct spade terminal.
Every search I use just leads me to a thousand listings for the larger 6.3mm yellow crimp style.
Anyone know where I might find the larger size I'm looking for ?
Also one of the distribution services is 'Maintained' i.e. Bilge pumps. What is the opinion on the supply source position for this - before the associated isolator i.e. direct to the battery or switched ?
It is simpler to feed it switched as there is a busbar serving the adjacent MCBs to other main services, but I guess a pre-switch feed would be better because then I can just turn off both Isolators to turn off the whole boat except the essential services. Due to the ridiculous position of the original Isolators they were never turned off.
BTW this thread fully complies with a thread I started a while ago asking if all electrical problems were poor connection related !
