Laptop power
Chris_Rose
24 Jul 2003
Staffordshire
I am looking for a cheap 12volt power supply for my Dell laptop, so i can run it from the yachts on board supply.
Anyone got any good contacts for these???
cheers chris
<hr width=100% size=1>"if it aint broke don't fix it, or get a bigger hammer"
iangrant
By the Sea
<A target="_blank" HREF=http://www.globalpositioningsystems.co.uk/search.php?PHPSESSID=3ae7bb2bd1ffe8bcef7eb52077c422a7&search=laptop>http://www.globalpositioningsystems.co.uk/search.php?PHPSESSID=3ae7bb2bd1ffe8bcef7eb52077c422a7&search=laptop</A>
I bought one last week - it comes with all the different plugs and voltages from 14 to 20 plus a polarity choice..
Works a treat
Ian
WayneS
21 Jan 2002
Hampshire
Be careful with Dell's. They are not consistent on what plugs they need.
What Model Dell have u got?
W
WayneS
21 Jan 2002
Hampshire
I am sure that the CPT has a 3pin feed with the end profile looking like a dome. Am I correct.
If so, the multi chargers that you get for arounf £30 will not work (They come with the conventional round connectors.
I got one for my Inspiron from a specialist supplier. I think that it is the same one that you need. As my Inspiron is now dead, I may just have the DC supply lying around somewhere.....
Cheers
Wayne
paulburton44
29 Jul 2004
Sleaford
www.withamsailingclub.co.uk
you might need a bit more power than 3-4 amps
my laptop needs 6amps at 19v. i bought a 6 amp lead from ebay. don't leave plugged in when engine starting !!!
check the rating on your ac power adp.
paulburton44
29 Jul 2004
Sleaford
Maplins unit ...
Left plugged in when starting engine - absolutely no problem.
OK -that is no guarantee - but I did it by accident, as I normally disconnect power supply and revert to Notebook batterty for the few minutes to start engine and then plug back in again after starting.
If I remember rightly - the Maplins unit is 70W cont ...... and even though this seems a little on the low side - charges my 16V notebook just as well as if it were on mains 240V
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
