Greetings all, I am trying to connect a laptop to a Evermore 320 smart antenna via the 9 pin db connector. I know what the wires are from the Evermore but do not know what the 7 wires from the db9 plug are. Any help apprcieated.
Thanks for the quick replies. I have a pinout plan, but I do not know which wire goes to which pin. The db9 plug looks like it is factory sealed. Can you buy just the plug without the wire?
Just been down that road: first, serial to usb, then buy the DB9F bare (solder) connector + the housing (body which is assembled around the connector. You'll find this on ebay for pennies.
PM if you want a photo
My notes have for the serial connector <u> on the laptop </u> are:
pin2 data out
pin 5 ground
pin 9 data in
Can someone confirm this or correct me if it wrong as I got these details ages ago.
My GPS / Laptop connections are pins 2, 3 and 5. 9 is not used. This agrees with the pin-out diagram posted by rickp.
BTW, for soldering these connectors, a very small iron, say 12 watt is very handy.
