pcatterall
Bought a 12 to 20 volt DC adapter from Maplin. I had hoped that one of the range of supplied connectors would suit my D400 note book.
Plan B is to cut off the connector from the mains charger so that I can use it with both the mains and battery chargers.
In my (usual gung ho) ignorance I assumed that there would be just two wires and that polarity would be the only issue.... not so of course!!
There appears to be an outer woven shroud (-ive) and inner woven shroud (+ive) and then a central wire ( no power detected)
What is the best way to connect this lot up bearing in mind that I need to be able to swap the connecter from the mains to the battery charger with some kind of plug and out device.
Or any other solutions!
Regards Peter
Regards Peter
