Lanolin
carlton
8 Sep 2005
A parallel universe.
.........applied to outdrives, props and trim-tabs.
Very easy to apply ( - Mrs. carlton did it /forums/images/graemlins/smile.gif - )It's a bit messy, but should provide better results than that £20 per tin Trilux rubbish. I'll report back next year when she's next lifted. (The boat - not Mrs. carlton).
Thanks Gludy - that will provide comfort to my very "sticky" SWMBO ! Although "just as good" denotes it'll be [--word removed--] !!!
After one or two months the drives appeared as though they'd never been antifouled with Trilux - hence the change to lanolin.
Apply with a gas torch to make it runny
- or you can do it the way I/SWMBO did, using two coats.
Mix a bit of lanolin with white spirit - slap it on with a brush. It dissolves easily and soon dries. Then, take a metal canister, stand it in a pan of boiling water, chuck in some lanolin (it looks like pink coloured lard, for want of a better description), stir it as it melts, and slap it on again for the second coat. It solidifies almost as soon as it contacts the drive/tab/prop/whatever, but you can't put too much on. It is very easy to apply, and - unlike the proprietary brands, should work well.
I understand it's been used with great success for hundreds of years in some far-flung Johnny-foreigner place, so I have high hopes...................we'll see.
David - does this mean that your props are still free of any growth whatsoever - and, when you say "last year", exactly how long ago would that have been ? (i.e., 12 months ago/18 months ago, etc.)
It's good stuff. I've used it this season and I've only had a bit of patchy light weed growth on the outdrives which falls away easily. I didn't try it on the props as I ran out of the stuff, and they fouled badly between outings.
I'll try and get a piccy with the underwater camera next time I'm down.
OK! a bit more explanation me thinks.
I visit my boat in the Med every couple of months in the summer. During that time barnacles grow on the SS props which, when I come to take it out, is like 80% of my horsepower has been taken away. So the applicaction of lanoline was to eliminate the barnacle build up while the boat is sitting doing nothing, which it has succeeded in doing very effectively. I would have thought though that as soon as the props start to whirl that most of it would come off so I have no expectation that it's a just once a season activity. My expectation is that I will have to give the props a "dollop" every time I leave it to come back home.
Coincidentally, we were discussing this a couple of weeks ago. A friend of mine mentioned that he uses lanolin for a wide range of boat-based applications. However he used something called "Wool Fat" that he obtains from a chemist. It is apparently 100% lanolin and performs better than lanolin based greases.
...this is what I use, I think the other stuff is harder and in consequence may have better clinging on properties. Incidently I get mine through an internet company and only get blank looks from the chemist when I ask...do you know which chemist group your friend uses?
I heat it in a saucepan and give the sterngear and props a good plastering fast before it hardens again.
Last year the lanolined sterngear was perfect when the boat was lifted out in the autumn. Boat hasn't been lifted this year yet but I noticed some weed growth when I was moored in a different location for a couple of months. So maybe, the success of lanolin will vary from place to place.
Propshield does contain lanolin, I used it on a Gori prop last March and am hoping it works. I'll find out when the boat is lifted. The red colour identifies it. But it's £35.00 a tin compared to about £7.00 for pure lanolin from a pharmacist.
I tried pure lanolin on a previous boat and it worked up to a point. Mind, it keeps your hands very soft....
