Bertramdriver
OK I'll own up, sometimes on long runs the Detroits exhaust noise gives me a head ache. To tame the beasts I've been experimenting with mufflers to redirect the exhaust gas into the seawater slip stream rather than broadcast the exhaust note behind the boat in the open air. The prototype mufflers are in fact doctored stainless steel 10" diameter cooking pots with one half of the sidewalls cut away.
Surprisingly, and after shifting the escape angle around a couple of times, they have been quite effective at redirecting the exhaust fumes away from the helm, so no fumes. Also they have reduced broadcast noise by a significant factor. (I keep forgetting to take my sound meter out with me so I can't quote numbers) The downside is the "hammer" effect of the exhaust pulse smacking into the flat bottom of the pot before escaping from the side, transmitting vibration and attenuated noise into the helm area via the transom wall.
So, I'm confident enough in the principle to move to the next phase which is to replace the cooking pots with a 60* curved pipe. This should smooth the gas flow and eliminate the hammer, allow me to direct the exhaust down into the slipstream, whilst retaining the benefits of quieter fume free motoring
Look at this on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=400787537329
45 degree bend, single skin stainless steel, flue pipe systems, ducting
My quandary is whether or not the stainless steel (almost certainly 304 rather than 316) will be strong enough to withstand the pressures and the longer term effects of corrosion in salt water. My thought is to laminate the steel externally with glass mat and high temperature resin, but I'm wondering if covering the steel with a strong material like GRP, having a low coefficient of expansion isn't going to cause warping, cracking and other nasties. The internal surfaces will rapidly acquire a water resistant finish once the Detroits start blowing through.
Does anyone have any experiance or thoughts on this mix of materials?
