davidpbo
Laminate flooring underlay as foam backing for vinyl headlining.
Anyone used it?
Anyone know what it is (chemically)?
The headlining on our boat needs replacing, I have used the same foam as was originally installed on one panel I have replaced but was wondering about using the type they use for underlay for laminate flooring. I don't know whether the spray glues or evo-stick type glues would react badly with it. I also want to check whether is is low fume and flame retardant.
Anyone know a manufacturer I could interrogate please?
I have a look at the foam backed vinyl from a well known supplier but the foam backing is only a couple of mm. I have yet to ask them whether they do thicker. The stuff installed is 6 or 8 mm thick form memory.
Anyone used it?
