srsm
New Member
On starting my engine it races to full speed - only stopped by closing off air supply. Throttle and stop levers make no change. The engine has not been used for a few years except for occasional running at idle. The fuel is old as well which might have resulted in varnish or wax issues.
Governor is mechanical centrifugal type. My guess is that the governor is gummed up such that default full throttle stays stuck. Odd thing is that stop lever has no impact as I assumed this would be a fuel kill 'switch' and so bypass governor issues...
I've replaced fuel and no change (not a big surprise but a good start).
Any ideas (and is removal of governor for check an easy operation - I have no manual with that level of detail).
Cheers
Cheers
