knot problem
baltic
18 Sep 2004
so would i but im not overgood with braid on braid and fingers a bit stiff now Im fine with ordanary 3 strand
prv
29 Nov 2009
Southampton
I would splice.
Alternatives might be to look up that halyard knot that Selden recommend, or Sailorman's suggestion of a buntline hitch is interesting.
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
what knot should i use to fasten snap shackles to 8mm spinacher sheets
Simondjuk
29 Aug 2007
World region
It's that simple, is it? :)
As for a different knot being more resistant to flogging, surely that's not possible and there's only so much flog resistance anything needs anyway. Have you ever tried to get a halyard knot undone? It's nigh on impossible if not actually so.
ghostlymoron
9 Apr 2005
Shropshire
If it's been used under tension (which it probably will be) you have to cut it off. I only tie it once a year so lose a few inches off my halyards each year. This is not a bad thing as it also moves the compression point over the sheave each year. By the time I've run out of halyard length, they will need replacing anyway.
