discovery2
Went down to the boat to check her before the storm arrives.......
Opened the engine hatch and was surprised how cold it was in there compared with the saloon and the rest of the interior. Obvously the wind blows through the intakes and makes it quite cold.
On the one hand, low temperatures in the engine space don't particularly concern me as the engine has the recommended strength of antifreeze etc., and our climate is relatively mild, however there have been several postings recently concerning placing heaters in the engine compartment, and it appears that many use the low wattage types.
My questions thererfore are:
Do you find the heaters effective? Having experienced the draught passing through the engine room, I would have thought that the small amount of heat produced by the heaters would soon dissipate with minimal increase in temperature!
Is there a (designers?) formula for heater wattage compared with engine space volume? or do es one just 'guess'?
Does anyone block (close) the intakes to stop the cold air circulating through the engine space? This could probably raise the temperature quite considerable by preventing the cold air circulating (obviously one would have to remove (open) them before starting the engine!).
David
David
