Skylark
I had a very small, less than 10mm, line of "rust bleeding through" the Sika from the trailing edge of the keel to hull joint. This was a new boat, seen at the time of haul-out at the end of the first season. The dealer repaired it under warranty.
A bead of Sika about 100mm long was removed from both sides of the keel. The minor rusting was cleaned and painted and a new bead of Sika applied. At next haul-out, this U shaped bead came off during jetwashing of the hull. I wasn't unduly concerned and thought that the ambient temperature may have been too low for successful application. I did a similar repair myself at the start of the following season but waited for the temperature to increase, a couple of weeks before launch. Guess what? This U shaped bead also did not adhere.
This second picture shows that the bead had not adhered after 6 months under water. It came off a few minutes after I took the picture.
I'm now preparing for season launch so I'm hoping for "third time lucky!"
Has anyone successfully repaired a bead of Sika along the hull/keel joint, butting against an old run? I've used 291i and cut the old with a sharp knife to create an angled overlap. I've read a lot about CT1 on this forum, would this be better than Sika? I'd really appreciate to learn from the wisdom and experience of the forum.
Many thanks.
Many thanks.
