zeds
Anyone who found the earlier post on preparation for Coppercoating useful might like to see the spec sheet for Hycote 152LV, the 2-pack epoxy preparation for keels before Coppercoating.
*Hycote 152LV is a high performance two component anti-corrosive epoxy coating, for protecting steel surfaces in the marine environment.
* . . is specifically designed to provide long term corrosion protection to steel and concrete surfaces.
* . . can be applied to damp surfaces, and consequently is ideal for coating hydroblasted steel.
* . . is a 100% solids, high-build resin, that shows excellent tolerance to manually prepared substrates.
It is not practical for me to clean to SA 2.5 standard (grit blasting) but I am aiming for a very thorough grinding/wire brush finish followed by Hycote applied during a mild, dry spell (optimism!!!). Will update on experience of doing job in due course.
