JamieB
New Member
We have a slow leak coming from under a GRP ‘step’ where our furthest aft keel bolt is located (pic attached). We had the keel remover three years ago to inspect keel bolts and re-bed the hull/keel joint. It was found to be in good shape and a load of new sealant was applied (after removing old) before bolts were torqued to correct load. It appears this is a slow leak coming through where the trailing edge of the keel meets the hull.
I’ve been thinking about how to resolve this - and am clearly not keen to drop the keel again unnecessarily. One idea I had was to install a vacuum bag around the offending spot in the bilge and vacuum epoxy through from the outside using a second bag to fill the void. I was assuming an initial pre-vaccum could help remove any residual moisture.
Does anyone have any thoughts on this as a concept? Any thoughts greatly appreciated.
